Odd Electrical problem under the dash
1 Publications
1 Utilisateurs
2,837 Vu
(@crowek)
Publications: 1
[#2523]
Hi,
I am about to pull the dash in order to replace the blower motor and the resister. While at it, I want to deal with two problems for which I have no potential solution aside from cleaning up the grounds. First problem: when I turn on the blower, the fuse blows, disabling the wipers. I will be checking out the switch (it is new) and the connections when I get the dash out. Second problem: In the past few months, with no discernible pattern, tach, fuel gauge, temperature gauge and indicator lights for the turn signals, battery, and oil/engine fail to light up. Re-starting the van seemed to solve the problem. This does not affect the turn signals themselves and the indicator light for high-beam continues to work. The problem has been intermittent, now constant. Has anyone else had either of these problems? Am I headed in the right direction(s)?
Please help.
I didn't find the right solution from the Internet.
References:-
https://www.thesamba.com/vw/forum/viewtopic.php?t=682156
Online Video Production Service
Thanks!
Posté : 28/07/2018 4:28 pm
